Rhyolith
A number of single pinion old hand drills have a small bolt that rides up against the crank wheel, keeping the cogs on the drive pinion gear in engagement under load. Such an mechanism can be seen in place of a second pinion on this Millers Falls No.1 pictured here:
Millers Falls No.1 by Rhyolith, on Flickr
I can make a pretty good guess at how hard the bolt is supposed to ride up against the crank wheel (biggest gear with the spokes (does this have a "proper" name?)). However, it feels like something there should be a method for... in other words there should be a perfect position for the bolt or the "Adjustable equaliser bearing" as i have heard it called. Does anyone know how to do this?
