Hi,Make the shape you want freehand on the bandsaw, using something like below,
apart for obviously having a jointed face and edge on the scrap like one would expect for use with a fence, as it seems whoever pictured below doesn't own a plane of some sort.
Not even a hint of a pushstick either, terrible picture really.
Crosscut a short section of wedge material, simply flipping it around makes identical wedges.
Do it just like the picture. The bits cut off the front fence becone the wedges. That way the holding side of those wedges is parallel to that fence. Tip to remember with wedges is thin (low angle) ones hold better than thick(high angle) wedges.
Regards
Looking at the OPs picture I would say it was done like you say in the last sentence.What pollys13 was aiming at, i think, is that if you cut the wedges from the rectangle to gain both the shaped piece and wedges, the wedges ( to tighten to the workpiece as there'll be a small gap ) would go in past the edges of the shaped piece.
Of course you just cut the original shaped piece 2" longer than needed, cut the wedges out, then cut an inch off each side of the shaped piece.
Thanks.I do a bit of woodcarving and use a similar work holding jig sometimes, except I do not trap the piece on all four edges, but hold it in a U or L shaped frame with the rear edge open and carve into the corners. That way I can easily take the piece out and flip it around to account for the change in the direction in grain.
Yes, you grasped exactly, why I was confused and explained the solution, great, thanksWhat pollys13 was aiming at, i think, is that if you cut the wedges from the rectangle to gain both the shaped piece and wedges, the wedges ( to tighten to the workpiece as there'll be a small gap ) would go in past the edges of the shaped piece.
Register today and take advantage of membership benefits.
