I bought the one from rutlands that was £30 reduced from £70
http://www.rutlands.co.uk/sp+pocket-hol ... -kit+DKPHG
It's not quite as good as I expected but I can see how to improve it to make it (almost) as good as anything else, it looks a bit like the trend jig but the trend jig is slightly better.
For a start, it's only set to give centred pockets on 19mm/ 3/4" stock, you can easily remedy that for stock <19mm by shimming the work piece until it makes 19mm combined, so for 12mm stock, add 7mm of packing on the hole side.
For stock larger than 19mm you need to adjust the height of the guide holes, on other similar models to the rutlands dakota, the height is adjustable because the part holding the guide holes to the rest of the jig has a slot, the rutlands one doesn't
However, it is held in place by 2 allen bolts underneath which give you about 6mm of height adjustment, which isn't particularly useful but it does mean that you can remove it and add a 'solution' between the base and the guide hole mechanism, my solution would be something like a simple hard wood/aluminium spacer and longer allen bolts.
I've just double checked on the rutlands website and the picture of my jig isn't quite the same as the one in the picture, there is a set of 4 holes missing, you can see one of them in the picture on the website just behind the base of the clamp mechanism, they're necessary for adjusting the clamp so that it will take 1 and a 1/2" stock. I've just had a nice phone call to nice lady at rutlands who offered me a full refund, it appears that they themselves have only become aware of the design change themselves on stock that came in last week :-(
I can see 2 solutions to this:
1. Get a set of 4 holes tapped
2. shorten the adjustment bolt on the clamp head. It's unnecessarily long, and it's still got a 1/2" or so that protrudes out of the end of the tube when it's screwed in as far as it will go, that will probably be enough, I'll test this method first and report back my findings.
I'm really reluctant to get a refund, for £30 + a bit of tlc, it can be whipped right into shape and be almost as good as anything else.
