how often to service my router
kityuser
12 Jan 2003
my freud is mounted inverted in my b&q table, my question is this:
" the other night I noticed a built-up of dust around the motor vents, how often do people remove thier router to service it? how about oiling the slide-posts???"
I`m thinking I would need to :
1) blow out the motor vents with my air-line
2) oil the slider-posts
3) remove clean and oil the collet
( 4) check the brushes?)
any thoughts anyone?
regards
steve
Chris Knight
14 Jan 2004
SE London - NW Kent
Steve,
For my table mounted ELU MOF 177 I blow out the motor housing every day - if I use the router that day. I clean the collet once in a while, when I notice any dirt or dust in there (I blow the collet housing out as well as the motor)
Haven't oiled anything for months, I have never checked the brushes. The router is about 8 or 9 years old now.
A
Anonymous
Guest
Same as Chris but I do oil the slides opnce a month - uisually 3-in-1 or Camelia oil, depends which is closest to hand. I find that the oiling definitely makes a difference to the sliding action
I think Trend market a collet care/cleaning kit but have never tried it
Tony
kityuser
12 Jan 2003
best get the hoover out tonight :shock:
sounds like that poor freud needs a hoover
A
Anonymous
Guest
hi kity user how do you get on with the freud router is it quiet how does it cope with things comments appreciated .
cheers
Rich
kityuser
12 Jan 2003
how do i get on with it?
Its a solid piece of kit!
Noise is`nt an issue as far as I`m concerned. I`m not really sure how it performs against some of the other bigger routers in this respect (dewalt, elu makita)
As I`ve said before I`m VERY impressed with the power. Raising panels is an experience to behold with one of these things!
The shaft locking mechanism is very solid with very little play, and I have`nt had any problems with the collet.
I know they are small points but you get a nice large chunky bit of flex with it, the speed control is easily accessible and the on switch feels nicely over engineered!
