Paul.J":25tr0fps said:
Isn't the rule of thumb to turn down to a third of the dia.So if a piece is 300mm wide you leave 100mm for drying??
The wall thickness has gotta be even all the way down but as Chipmunk says its usually the tenon that splits.
Make sure the pith is well out and anywhere there were small branches seal those well.
On saying that i had some pear and it turned lovely,a really nice wood to turn and in fact it was a piece of wet pear that was my deepest/biggest hollow form nearly 14" deep if i remember right and it didn't move at all.
Hi Paul, I reckon on closer to 10% than 33%.
So for your 300mm bowl I'd leave the sides about 30mm thick but the base would also be about 30mm thick too.
HTH
Jon
