How do you cut Dovetails - Poll
How do you cut Dovetails?
  • Leigh D4
    Votes: 0 0.0%
  • Woodrat
    Votes: 0 0.0%
  • Trend jig
    Votes: 0 0.0%
  • Fixed width jig (e.g. charnwood)
    Votes: 0 0.0%
  • Incra
    Votes: 0 0.0%
  • By hand
    Votes: 0 0.0%
  • Jig not mentioned here
    Votes: 0 0.0%
  • Total voters
A
Anonymous
Guest
Hi all
Thought it might be interesting to find out how people cut dovetails and what (if any) jigs they have/use.
Please let me know any that I have forgotten and I will attempt to add them to the list
Tony
A
Anonymous
Guest
I use the 'Screwfix' Dovetail jig, the plastic rather than alloy template, is the only minus point I've found with this jig other than that it does what it is designed to do.
Chris Knight
14 Jan 2004
SE London - NW Kent
Tony,
I cut them by hand, with the Woodrat and the Leigh, depending on the number and size I want - but your voting system won't let me put that in.
Now as to hand cut dovetails, do you cut the tails or the pins first? (I do both but on the whole, prefer to cut pins first)
A
Anonymous
Guest
Chris
I think that a user can only vote once on these things and so I think people should vote for their preferred or most used method.
One thinkg I hope to get from this is an idea of rat v leigh v other so-to-speak
Tony
gidon
19 Mar 2003
West Dartmoor, Devon, UK
I've only cut them by hand. I did buy a Elu jig recently but it was on Ebay after less than a week - I hadn't quite appreciated: 1 - how boring the joint would look; 2 - just how much time it takes to set up for one drawer; and 3 - that ideally front and back of drawers are meant to be the same thickness and the sides can't be less than 1/2" - not what I'm used to.
So still doing them by hand - for the time being .... With a large mix of sawdust and pva glue to hand :).
Gidon
Adam
10 Sep 2003
UK
I cut them by hand and with the woodrat. Like Chris, finding the poll doesn't have enough options!
Adam
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
I had a Leigh. The results were excellent.
BUT.
If you only do them occasionally (like me), the learning curve in getting it set up correctly, plus it is not silly person-proof, means that it took longer to do one drawer than by hand. If you have a whole kitchen to do, that is another matter.
Personally I either cut by hand with a Japanes saw, or on the bandsaw using Mark Duginski's method. Fast, aesthetically pleasing and accurate.
Steve
