How do I spot sanding marks, before applying a finish?
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
Can anyone please tell me what is available, in the UK, to allow me to spot any sanding marks before I start applying the finish?
It musn't have any impact on the wood.
Many thanks
Neil
White spirit and a bright light?
Adam
Hi Neil
I wonder if wiping the surface with Cellulose Thinners might show up any marks? This will also have the advantage of drying quickly and evaporating away to virtually nothing ready for any anything you want to put over the top.
White Spirit will have the same effect but would be slower, although this might be a good thing in some cases.
Look forward to seeing any other ideas!
Try a bright point light source at a low oblique angle to the work piece surface
Scrit
Plane rather than sanding?
I'd just spray a very fine mist of water on it and shine a lamp across
I'll get me coat
Hi all
Thanks for all of your suggestions. Terry has come the closest to what I have seen on some US sites.
Will it mark the wood or have an adverse effect on the finish?
Neil
Cellulose Thinners shouldn't cause a problem - once it has evaporated it has gone completely (assuming you're using a quality thinner) and shouldn't raise the grain or have any adverse effect on the wood
This is theoretical of course and not something I've tried but it makes sense to me... anyone want to volunteer to test this idea?
