stuartpaul
You know when you tell the missus 'just tell me what you want and I'll make it'?
Well she has and now I've got to work out how to put it all together! :shock: :shock:
A pair of wardrobes with drawers under. Just over 2m tall, 580mm deep and 1100mm wide.
I'm thinking either 12mm MDF with 6mm glued on to mimic the panelling or using poplar and manufacturing 'proper' panels with 6mm mdf or ply. Worried that both approaches wont provide the strength for quite of lot of hanging clothes which weight wise adds up.
Had some issues in the past with planting on 6mm, - seemed that the tension of the glued strips caused warping. Also think the panelling will look too deep, - thinking about 4mm or thereabouts.
Did think about 18mm mdf and routing the panels but life is far too short to take that much further!
I'm concerned about fixing full extension drawer runners as they'll need to be beefy to carry full weight and they're wide (1100mm). Drawers will almost certainly be 12mm birch ply (results of a previous post). I also have to make sure I've got enough 'meat' for the hinges, - probably clip on or similar.
I know people on here make this sort of thing for a living so hoping for some pointers please!
