how big is a Record DML 24X lathe?
Homerjh
17 Jan 2014
Runcorn
some on ebay and looking to bid but none have the size listed, and due to the available space I have I need to ensure it will fit.
so if you have one, can you give sizes (so length/etc) so i can check, i have asked on the auctions but not sure if i will get a response in time!
Can't help you on the actual lathe size but I owned one years ago and the stand dramatically increases the size of the footprint - so be aware!
49" if anyone was wondering!
too large for the room i have as was needing something less than 1 meter.
hmm, this may work as can trim to size, any idea how the bars are attached to the base and i am assuming they are solid so may be a pita to trim?
The bars are hollow tubes that are just clamped at each end onto the stands.
    8.4 KB
You sure on the hollow bars?
A friend's has solid steel bars. Cuttable with an angle grinder though.
Phil
