user 24853
New member
- Joined
- 2 Aug 2016
- Messages
- 2
- Reaction score
- 0
Hey all, new to forums, so hello all. Hoping to make this my wood tinkering haunt.
I've been slowly getting into wood carving, just testing the water so to speak for some potential monetary ventures. Right now, money is an issue, and I'm on a budget. Just for clarity sake.
Basically I'm in the middle acquiring a Rexon WG180A wet stone grinder (Very similar to the Makita 9820). I need this due to sourcing chisels secondhand, and other 'not finished' conditions. bevels not being at the 25 degree mark are taking forever on my 480 Diamond plate to shape. A few have 35+ (some at 45) and I just can't get the material off quick enough, I'm using this for shaping only. Complete honing and polishing will be completed with a combination of Diamond plates, waterstones and strop. I am without other powertool as of now accept a dremel and drill. Again just for clarity sake.
The Rexon is coming with a extremely worn wheel. Dimension are 180 x 20 mm with 12.7mm bore. (I don't mind using bushes) But I am having a problem finding a replacement to suit the tool. I am also very unsure if some wheels are not recommended to use with water, and if some are even safe to use, what is effectively, the side of the wheel.
60 - 180g would be great.
Thank you for reading, and any that are able to provided useful information.
~K
~K
