There are a lot of honing guides to choose from--cheap to expensive. Before I buy what have you tried & liked?
David C":534gnroc said:Sam,
The blue guide is Faithful, very badly made!
David
woodbloke66":3qp2tkun said:I've tried a few and all have their plus and minus points. The original Eclipse is quite good, but taken to it's ultimate form in the LN version which is fine for LN stuff and similar, but useless for Japanese chisels. I also used for many years the Richard Kell guides from WH which again are good, but take a bit of getting used to. Currently I use the Veritas MKII which is IMO is just about unbeatable as it will handle everything you throw at it. I use it currently on the SS 3M films from WH; works fine - Rob
Yeah? I would have thought it would hold better than the ones you can buy for £10 or so. Assuming it still has a slight curve to one side. But no doubt it will still have milling issues.David C":10kcqj4c said:I think there is something seriously wrong with the shape of the chisel slots, on the Wish guide seen above?
David Charlesworth
