Following on from my home made fingernail jig, I've been meaning to make a set of cole jaws, so with some free time this week here are the results.
4 pieces of 5mm thick aluminium, taped squre together with the diameter and segments marked.
Cut out on the bandsaw and mounting holes drilled.
Fitted to the chuck and turned to clean up the edge.
After drilling 120 holes!
Solid wood doorstops with a taper turned on the lathe.
Adding the mounting hardware.
With the buttons fitted.
From behind.
In use!
I have finished a few bases now and wish I had made it ages ago!
Just over 16" when closed.
Thanks for looking.
Chris.
From behind.
In use!
Thanks for looking.
Chris.
