DaveL
After seeing the review that AndyG did of the Axminster MTM air filter I decided to have a go at making my own, using Axminsters filters.
I ordered a pair of replacement filters. along with a couple of boxes of staples to break the £45 free postage mark, here is the main filter as it came out of its plastic bag.
The filter is three pockets to give maximum surface area for the fine dust to be trapped on.
I had a fan that came out of a 19" equipment rack many years ago that still works and should be up to the job.
I sorted out some 2"x1" and used my pocket hole jig to make a square frame for the filter to mount on.
This was clamped with glue and then screwed.
I routed a hole in a piece of ply for the other end of the box and fixed 4 more lengths of 2"x1" between the ends. Here I am checking the filter to fan clearance.
I covered the sides with second hand hard board and ply that was in the now infamous scraps pile. Here is the fan mounted complete with finger guard.*
I fitted another frame around the filter and then a pair of battens with some dowels to hold the outer filter in place. There is about 8' of foam draft strip stuck on the the box and filter frame.
A couple of simple frames screwed to the rafters and the unit is mounted ready for use.
Its not as pretty as the Axminster unit but it does work, here is the outter filter after I had planed and thinknessed some sycamore boards.
*should the guard have been removed for photographic reasons?
