Hobby cnc users.
Eyesaw
22 May 2019
essex
Hello.
I fancy having a go at owning and using a cnc machine.
Are there any members on here who could shed some light on this subject.
Looking on you tube is a minefeild and mainly for the u.s market.
Thank you
Eysaw. :D
sammy.se
3 Aug 2014
London
Peter Millard on YouTube just started a series on CNCs, UK based (Essex) supplier. That will get you started.
Sent from my SM-G973F using Tapatalk
oakfield
7 Oct 2009
East Sussex
I have an eShapeoko which is similar to the X-carve which I’m sure you would of seen if you’ve been looking on YouTube.
Are there any aspects of it in particular you have questions about?
Eyesaw
22 May 2019
essex
Thank you sammy.se.
I will look.
Eyesaw
22 May 2019
essex
Thank you oakfeild.
Iv'e been looking at videos on the shapeoko.
I know some about cad as i participated in a cad course at college some years ago.
What becomes a minfeild for me is knowing what software and hardware is good value for £££ and which hobby cnc has the largest available part suppliers for the uk market.
Bodgers
21 Dec 2014
North Yorks
I have a 750mm 2nd gen (2017+) X-Carve. Happy with it. The support around it is excellent. The X-Controller is plug and play, no messing around. Pretty easy to put together with the 2nd gen as it is all plug-in connectors.
I mainly use Fusion 360 to design and generate tool paths with its CAM mode, but if you want to keep it simple, Easel is very straightforward.
Eyesaw
22 May 2019
essex
galleywood":3te798v6 said:
There is a CNC workshop at Barleylands where you can rent a machine for a trial, I believe.
That sounds interesting and a path that could well worth trying.
Thank you.
Eyesaw
22 May 2019
essex
I think easy to use could be the way to go. Whst is the largest workable size peice you can produce on your x -carve ?
Steve Jones
18 Dec 2007
Halesowen
Hi
Build your own, I did, took a lot of research and sourcing parts but glad I didn't splash the cash on a ready built machine. Since those pictures I've swapped the Bosch router for a 1.5kw air cooled spindle which is much quieter and at the moment I'm updating the gantry plus I'm using the cnc to cut it. As for speed when I cut the new gantry sides and back last weekend I was running at 200 inches per minute, obviously for more complex shapes I run it quite a bit slower.
My CNC build
Steve
sammy.se
3 Aug 2014
London
Steve Jones":1g0h365s said:
Hi
My CNC build
Steve
Hi Steve, what was the total cost, all in, of building your own?
sammy.se
3 Aug 2014
London
Ah, I just saw on your thread - it says between £500 and £1000.
Eyesaw
22 May 2019
essex
sammy.se":3nw250lx said:
Steve Jones":3nw250lx said:
Hi
My CNC build
Steve
Hi Steve.
Thats right up my allie but i would not know what to buy where to buy it or how build it especialy when talking electrical components or software.
Eyesaw
22 May 2019
essex
I've just looked at your cnc build thread.
Well done what a fantastic job.
i'd be very proud after making that.
I don't have a lathe or know anybody who does.
Well done.
Steve Jones
18 Dec 2007
Halesowen
Well done.
Thanks, must admit there were a few times I nearly threw in the towel but glad I stuck with it in the end, it even earns me a few pennies occasionally now :lol:
Steve
Grawschbags
17 Jan 2016
Central Scotland
I have an Ooznest WorkBee CNC. Really pleased with it so far, and it's a solid bit of kit.
Not used it in anger yet, other than to test it. I'm in the process of building a soundproofing enclosure for it as it's really loud using the dewalt router, and I don't want to upset the neighbours...
Don't worry about software at this stage. There is plenty of free stuff out there to get you up and running, then you can upgrade as necessary.
andys wood shed
21 Sep 2006
I've got a Ooznest Workbee and are very pleased with the quality and support as it's manufactured in the uk
It is lead screw driven as opposed to belt driven
They also supply components for build your own
https://ooznest.co.uk
Bodgers
21 Dec 2014
North Yorks
The 750mm capacity is just over 500mm square. But, that's not a complete restriction, as you can key a work piece in and move it along to do longer pieces.
There is a larger one at 1000mm. And a smaller at 500mm.
Eyesaw
22 May 2019
essex
Hello again to all who have participated in this thread.
I'm still undecided on which cnc router to purchase.
I've heard of a british company called ooznest and they produce a cnc router set up with a working area of 1300 x 1300.
There are promotional videos on you tube but I haven't seen any in depth reviews.
Does anybody on this site have experience with this company.
I think they call there machine set up workbee.
I'd be interested in any information regarding these from actual users who have purchased through ooznest.
Thank you.
