Hinge question.
skipdiver
14 May 2008
N.E.Lincs
Can anyone tell me which Eurohinge (Blum?) i need for 21mm thick doors attached to 15mm carcasses, full overlay application. I know there are several different types and backplate configurations. Never fixed that thickness door to that thickness cabinet in the past and don't want to have problems with reveal distances and binding problems.
Looking at the blum reveal and overlay tables suggests the 95 degree hinge would do the job or can i just use a bog standard 110 degree hinge with a bit of experimentation. I am drilling the hinge holes myself, so can adjust the edge distance accordingly.
Any pointers gratefully received.
Thanks.
Any of the usual Blum hinges will do but you MUST use a +3mm mounting plate.
J
Thanks Jason.
I had another look at the tables and came to that conclusion, so thanks for confirming it.
