Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
We're doing a major room refurbishment, and we've borrowed a tower to help with the ceiling, etc.
It's a really nice and well made Youngmans one (all aluminium), with a built-in ladder at each end. I think it uses half a ply board (cut lengthwise) as the platform - it's wide and narrow, and not a tower shape seen nowadays. About 18" of one end forms a trapdoor.
Although all the metalwork generally is in good condition, the hinges for the trapdoor have gone and the platform board needs replacing. I'd like to repair it as a thank-you to the owner, but I'm struggling to find suitable Tee hinges as they're odd:
One hinge leaf is flipped over from normal. You can see why from the way it's used. When it's open, the asymmetry lets you prop the trap just over vertical (like the stay on a church bell), and when it's closed, it lays flat, with no obstructions on the decking's working surface.
I've spent a long while Googling: I can't find similar hinges off the shelf, anywhere, at any price. Does the team think these are "specials" or just that I don't know what term to use when I Google?
I've looked for:
The originals are (were) simply galvanised, and not very heavyweight mild steel. They managed at least 20 years, so any replacement will probably do, as long as it's the same weight and works the same way.
Does anyone recognise these and can you suggest a supplier? My last resort is to drive the pin out of a normal one, swap the leaf over, and tack weld the pin back then carefully paint it well with something like Galvafroid or Hammerite.
Very open to ideas, but I've looked at a lot of other hinge designs and I haven't found anything so far that will do the job with the required safety.
TIA,
E.
I've looked for:
- Reversed Tee hinges
- Cranked Tee hinges
- Reverse swag Tee hinge (think this is technically correct)
- Offset Tee hinge
TIA,
E.
