Hexagon Wine Rack
Ryandotdee
4 Nov 2018
TIVERTON
Hello, first time posting a project, any feedback would be welcomed. I just saw a post from PeteG on some hexagon shelves, and as it was similar to what I had made this weekend I thought I would share it as well.
The body is made from Ash, and the interior rack and keys are american walnut. I am very new to working with hardwoods, I have only recently moved up from cobbling things together from wood bought from Homebase. It is really rewarding, but also alot more costly when I make mistakes!
Originally I wanted to make the rack hold 7 bottles, but my measuring was a bit off so I had to suffice with 5.
I like that. How did you ensure all the mitres came up tight, they look good and accurate along the whole depth of the unit.
Fitz.
Very nice fella, I love the Butterfly joints, something I've never attempted. Don't worry about the
mistake, it happens, and you'll forget about it soon enough.
Really nice.
A while back I attempted an octagonal tray, with finger joints. I succeeded (sort-of) with a jig for the router table, but it was a huge headache getting it to work properly, and the result was nothing like as nice as I'd hoped. Those butterfly splines ('keys'?) are pretty impressive!
If that's a 'first go' in hardwood, you have a bright future!
E.
Fitz.
Thanks Fitz, I used a combination of masking tape to initially assemble the joints and pull them together, then I used a band clamp wrapped around some corner braces which I cut with 2 30 degree angles.
One of them did not come out very well and had a 1-2 mm gap along the whole joint, so I ran the joint back through the table saw and after that it came up flush.
Thanks Pete
Full disclosure, I would love to say that I had cut them by hand, I did start cutting them by hand but it took me about an hour to do one, And I was petrified of cocking one up and ruining the whole thing. In the end I used a router to cut them so that I could be sure of a uniform result.
My hand tool skills are better than they were, but I have a way to go before I can rely on them for uniform results!
Eric The Viking":23kuv5t7 said:
Really nice.
E.
Thanks Eric,
It is not my first project in Hardwood, I have been working with hardwoods for about 3 months, but I would say that this is by far the most complicated piece I have done so far.
I am happy with the splines, I was a bit worried about cutting them by hand so I used a router table, I made a 30 degree wedge so that I could run the whole thing through level.
Thanks Pete
Nothing wrong with using a router fella ( for me anyway ) still takes skill and accuracy to get it right :D .
