hi i am completely new to wood turning. I have a Tull international lathe, which is fairly old but works OK.
but i am having a problem with the drive center. I can't find how to remove it so i can attach the bowl plate. The drive center has 2 flat spots either side of the shaft, which i thought a spanner would turn it as if it was on a thread, but it hasn't worked i cant pull it out either. The bowl plate also doubles to tighten on to the bolt that holds the tail stock secure.
i know there are problem some bits missing from this lathe i did have to buy a tool rest for it.
