paulie75
Hi all,
Newbie post alert!!!
I'm not too sure if this is the right section but I shall fire away and seek your advice. My query is loosely woodworking related, more specifically to do with deck construction. The timber elements I am ok with although there is a lot of variation and opinions as to what is regarded the correct way to propagate. American, Australian, and European techniques are all different. While some seem content to simply place on paving slabs, I would like to build mine to last.
There are many schools of thought on the best way to suspend a deck, and the best way to sink the posts in the ground. I am resolved in my framework and how it will be supported. From what i gather when setting posts in cement the main priority ( apart from being level) is to ensure that they will not sit in standing water. So from this I have decided that a 12"x12" ring of cement around the post will adequately support it. (4x4 post) with the aforementioned post in the middle. I also understand that the general accepted ratio of above ground to below ground is 25% . ie: 4' post = 1' underground. To prevent water build up at the bottom of the post hole with pea shingle , about 6 inches to create a soakaway. So far , so good?
After that incredibly long winded preamble , my question is , would it make sense to precast the concrete supports? I want to make them a decorative feature, so I was thinking of building a shuttering box out of a laminate of 18mm ply and thick plastic sheeting. Each "cell" would be 1 cubic foot with a plastic lined 4x4 in the middle of the form, pea shingle in the bottom so that it could mate to the pea shingle soakaway in the hole .The ply box would be 4' x 5' to make 20 supports for 3' posts.I feel that this would create consistency in the supports and would save time in the deck construction.
~In your opinion would this be a feasible option or am I trying to re-invent the wheel. Please ask for clarification if I have not been concise enough. Thanks in advance for your suggestions and advice.
