Help with choosing a disc sander.
Des333
27 Jun 2016
Newcastle upon tyne
Some advice wanted on a disc sander about 10” diameter for the bench. I’ve decided I need a disc sander as the Picador linishers don’t do what I want to do. I’ve been looking at Record and few others at around £230 which seem ok all with their faults. Also been offered a Picador 10” bench sander, motor driven not belt, for about £60. So what’s the thoughts on the picador, is it worthwhile investment or would a Record or similar be a better machine?
All replies and comments appreciated.
It would I suppose depend on what you intend to do with it?
What's the thinking behind this and what is your current setup not doing for you?
(I can't offer any direct advice but the answers to the above will probably make it easier for those more qualified to offer meaningful advice...)
This is a pretty decent machine, Draper have the same unit on a different stand and with a little bit better table for a bullseye more. I will get around to making a bigger table for mine when I get the time and the room
