Fromey
Warning: Dumb question to follow
I recently bought an Axminster cheapo bench grinder and tool rest;
http://www.axminster.co.uk/axminster-ax ... rod789070/
and
http://www.axminster.co.uk/axminster-ax ... rod364782/
Unfortunately, the metal supports for the tool rests affixed to the bench grinder are in the way, so I disassembled the wheels and removed them.
Now that I've reattached the wheels I've found that when I screw up the locking nut for a wheel, it gets to about finger tension and then the threaded axle that runs through the bench grinder starts to turn, so I can't tighten the nut very much. The two threads are in opposite directions, so if I try to hold one of the bolts while I tighten the other, it just undoes it. There's insufficient axle protruding from the nuts so that I can't get a pair of locking pliers on them. Thus, there seems to be no way to lock the axle so I can tighten the nuts up fully. There is no information about this in the manual.
Is this normal? Will they tighten themselves up through centrifugal force once I turn the grinder on, or will the wheels come off?! Or am I to tighten one wheel while the other is removed and I can hold the axle and then hope there's enough tension on the first wheel to allow the second wheel to be tightened?
Thanks in advance.
and
Thanks in advance.
