Help with a Dewalt Dw110 Radial Arm Saw...
I hope this is the correct forum...
Can anyone help please. I need to get a new blade for the above RAS. 40 to 60 teeth is fine. I understand that table saw blades are not a good idea but I have no idea where I can buy the correct blade from...
Thanks all.
The hugely important thing is you need NEGATIVE RAKE blades. Those are the ones designed for RAS and cross cut miter saw.
If it doesnt say negative rake on it just dont fit it.
Negative rake saw blades are a relatively new creation that came along when the portable mitre saws and carbide teeth blades came out. Before that any table saw blade would be used as the saws were often the only saw a person had and were used for everything, crosscutting, ripping, dados/trenching etc. That said it is safer to use a negative rake blade just remember to keep the hands well away from the blade path as they like to eat the hands of the careless.
