bluenose
Hello folks, I am in the process of replacing all of the doors around my home.
There are two doors that will require some additional work on them. One of the doors is only about 3/4's of the normal door height and the other is where the top of the door is very angled.
I have (hopefully) attached a couple of images so that you can see what I am trying to achieve. The thought in my mind is to cut the two doors to suit/fit their apertures and then with my router I intend to route a new groove to match the originals and then to fill the grooves that are no longer required. I'm thinking that I can do this with a decent quality woodfiller (any recommendations very welcome) and then to sand this down so that after painting the work will not be visible.
The grooves in the new doors can I think be described as being flat bottomed 'V's, I'm sure that many of you will know what I mean, indeed some of you probably have them installed in your own homes. They are I believe quite popular. If anyone is aware of where I might obtain a suitable router bit, is it possible that such a bit will be available?
Please excuse the poor quality drawing but i think that it just about serves its purpose!
Any help/guidance will be much appreciated. Thank you.
