RobinBHM":2llbayl4 said:The easiest way is to make a template first in 9mm or poss 6mm mdf. Bandsaw or jigsaw the shape, very carefully following the pencil line. Sand to remove any bumps (an offcut of mdf with some abrasive glued or double sided taped on is ideal, you want abrasive with a hard backing).
Then use a bearing guided straight bit, then moulding cutter with bearing.
