BTR
Been a while since I posted nice to see the forum doing really well.
Yesterday I was cutting a piece off 18mm ply on my table saw a deft t30 I have had it since new a it has been very lightly used.
It turned on fine and run as usual no probs i finished the cut and turned it off then i went to turn it on again and it did not start up.
I pressed the start button and this time it started but very slowly and made a humming noise from the motor and it does not go up to full speed.
It sounds like the motor is not getting enough power so today I cleaned inside and out of motor and the cabinet but everything looks good any help and advice please.
I think it could be the on off switch I have attached some photos and a small clip of the problem.
