colinc
Hi,
I have recently been using an APTC Planer/Thicknesser (from memory an AW106PT2) in our airfield's workshop where we are busy making spar laminations for 'Black-Magic'. I am having a few difficulties that I thought someone familiar with the machine could perhaps advise on. The machine was bought second hand and I am not familiar with its history. My own machine at home is a Scheppach with rubber feed rollers and I find this one feeds badly in comparison. A lot of the time it needs helping along as it often stops feeding the timber and the serrated feed roller marks the surface. When I try to help the timber along it actually take a lot of effort to push it through as there is a considerable clmaping force from one or other of the rollers. Often there are dirty marks on the back of the wood where it is scuffing on the thicknesser bed.
I have tried very hard to make sure the bed is clean and smooth to minimise friction. The timber going through is just Sitka Spruce which is not in any way demanding to plane if I put it through my machine.
Another problem I find is that the timber does not feed as straight as on mine and because the clamping force is so high it is almost impossible to correct the run off. Sometimes the wood will ride up on the edge plates of the thicknesser bed and then get machined with a taper. The lengths of timber are typically 5/8" thick x 4" wide but sometimes up to 20ft long so being able to steer them is important.
Any thoughts? Is it possible that the feed roller is worn out or misaligned? Am tempted to replace it with a Scheppach, but funding for the project is tight at the moment and would prefer to solve the problem anyway!
Has anyone ever replaced a feed roller if they are available?
Colin
Colin
