Dissolve
Hello,
I recently set up a router table using an incra plate and a triton router and the results are very good.. however!
The only task I'm having issues with is routing I curved profiles using a template and flush cutting bits, I understand the theory of grain direction, so I ordered a 4 fluted template trim cutter from Wealden Tools and so far I haven't had great results..
My thoughts were to buy the long cutter with a bearing on each end so I could quickly flip the timber (with template attached) over so use the same bit in the correct grain direction, however I'm still getting nothing but tearout even when removing a miniscule amount of material.
The timber I'm referring to is around 40mm thick, is this too deep to attempt to route in a single pass? Should I ditch the longer bit and buy a few shorter template bits and route the profile flush with the template in very shallow passes and increase the depth of cut slowly?
Would this make it easier and avoid the bit grabbing when routing against the grain?
