HELP! jigsaw problems
Digizz
22 Jan 2004
Oxfordshire
I've got a Bosch PST850 PE jigsaw - had it quite a few years. I'm having problems (and always have had) with it not cutting perpendicular to the wood.
The blade is square to the base but as I progress across the wood (well, in this case MDF), the blade starts to flex sideways (to the right), resulting in an angled cut through the wood. This is whether I use it free-hand or up against a straight edge.
Is this something I'm doing or rubbish tool/needs some adjustment?
I'm trying to cut out a large opening in a sheet of 19mm veneered MDF. I'm using a Bosch progressor blade which does give a good finish (well- the edge that I need).
Any ideas?
Thanks,
Paul.
Alf
22 Oct 2003
Up the proverbial creek
IIRC, Lennox blades are frequently put forward as an improvement/solution. A search on Lennox should bring up some stuff I think.
Cheers, Alf
Digizz
22 Jan 2004
Oxfordshire
Cheers, Alf
Thanks Alf.
I got very frustrated in the workshop this evening - one of those days (mind you, I have been in the workshop most of the week - probably need a break!)
