Quantcast
Help identifying Chuck bits
RichardG
29 Mar 2018
South Norfolk
I was given a Record Power CL3 recently along with a box of bits. I’m sorting through the Chuck bits first and have matched up most bits but there’s a few things I can’t work out....
I have an Axminster 4 jaw Chuck with 3 sets of jaws, inner, outer and some with dovetail type jaws. I’ve found a face plate and a screw thread mount that fits these jaws.
I also have various centres.
These are the bits I can’t quite fit together.
After much fiddling I have manage to make what looks like another collar faceplate mount.
but I cannot work out what to do with the other bits? Any suggestions?
RichardG
29 Mar 2018
South Norfolk
As a non woodturner I can't help with your query but can't avoid a titter over the "bowel chuck" !!
Sorry, realised that I’d put collar rather than faceplate so edited before I saw your comment, so don’t worry you’re not going mad there was a bowel Chuck...
Robbo3
28 Jan 2012
Oxfordshire
Someone on here has a manual for that chuck.
From memory - with the knurled ring face down place 3 jaws inside. Place a suitable elastic band (yes really) in the groove at the base of the jaws. Add the taper piece, narrow end first then the chuck base. Invert & tighten the knurled ring.
The second photo are pin jaw chucks. There should be two metal pins which sit in the cut outs. When it is pushed into a suitably sized hole in the work piece then twisted, the pins roll in the grooves & get trapped on the side of the hole & give a pressure fit. Don't reverse the lathe or it will come loose.
The larger ring is probably just a face plate.
The 4 jaw chuck on the tea towel looks to be the renowned Axminster Precision chuck. Both the jaws & the carriers (the toothed bits that the jaws are attached to) are numbered but it is the carriers which need to be mounted in the order 1,2,3,4. If the jaw & carrier numbers differ it makes sense to swap them so they are the same.
The metal piece on the tea towel is nothing I recognise from the photo
okeydokey
21 Nov 2014
Burgess Hill
Hi Looks like a Record RP3000 chuck which uses an elastic band to hold components together while assembling the chuck for use.
Google and should find photos etc
If I'm looking at the right piece of metal - curved with a peg - its used to tighten/remove the chuck from the spindle.
I had one years past - didn't like it at all, did when I started but life became much easier with a scroll chuck
good luck with the cl3 lathe solid cant go wrong
RichardG
29 Mar 2018
South Norfolk
Thanks for the replies, searching for RP3000 has found a few pictures which has helped. What it has confirmed is that they offer no advantage over the Axminster 4 jaw Chuck so I’ll clean that up and get it mounted.
AndyT
24 Jul 2007
Bristol
I recognise those bits. I have a similar chuck.
I was able to understand it because member @nev scanned and uploaded the complete manual, back in 2013. Go to this thread for the PDF. There seem to have been several branded versions of the same thing.
RichardG
29 Mar 2018
South Norfolk
Thanks for that post but the Sorby pdf that can be downloaded is somewhat different to the bits I have. The other links now seem broken...
