help for best quality accurate electric mitre saw
stephenCC
New member
6 Apr 2020
stafford
i am looking for advice for purchasing the best quality mitre saw (sliding or chop) - for carpentry work. size and power not the issue - I need precision and accuracy, consistency on relatively small pieces of wood.
any ideas for the best quality finest wood cutting circ blade
Stephen
I have had a Festool Kapex KS 120 for a few years, I find it to be very accurate and easy to use.
Festool also do the KS 60 which has a smaller capacity, I am sure will be as good, it might suit you better if you are only cutting smaller pieces.
Accuracy and ease of use> Festool Kapex as above.
For bigger capacity> Bosch GDL 12. Mine is as accurate as the Kapex I have used, but more awkward to set up for compound mitres.
Both will do high quality work when set up spot on.
If you want accuracy on small parts I would advise a non sliding chop saw.
I had a virutex chop saw (non sliding) it was rock solid. I sold it as I now do all my fine cross cutting on a sliding table saw.
https://www.virutex.es/productos/?action=producte&id=69
Also have elu and dewalt sliding chop saws, they are not 100% accurate and you don't get repeat ability.
Sent from my SM-J530F using Tapatalk
Since you didn't include cost as a decision factor, you might consider the Omga line of saws. These are very expensive, and I've only seen one in action, but it was accurate and repeatable.
