Glynne
A bit of background in case it helps.
About 7 weeks ago I came home to find I had a leak in the loft which was dripping through the bathroom ceiling in which I have 4 of the lights below.
2 of the lights weren't working despite changing the bulbs but the other 2 were so as I probably need to replace the ceiling, I left things until it gets a bit warmer.
Separately, last week I changed the fluorescent tube in the loft to sort out some rubbish and everything was fine.
Today I went in the loft and the strip light worked for about 10 minutes and then one of my lighting RCDs tripped. As the only light on in the house was the strip light I thought that had to be the problem so: -
I took out the whole strip light assembly and tried the RCD - it wouldn't reset?
Tested the light in my workshop and it was fine so I re-installed it.
Then I thought that perhaps some water from the leak had go into the cables leading to the bulbs and had rusted causing a short.
So I've taken all of the lights out and tested them - all fine.
I then thought that perhaps it was one of the transformers and took them out. A couple were heat damaged but the other 2 were fine. Rather than mess about II've left them all out thinking that if they are not there then there is nothing to short.
Tried the RCD, it still wouldn't reset.
Tested every single light bulb on the circuit that trips - all absolutely fine.
Then remembered I have small extractor over the shower. Took that out and tested it, fine but again left it out.
As a final resort, I took the switch for the strip light apart, again fine.
I've just about run out of ideas so before I have to get someone in, does anyone have any suggestions please?
