Hello - and 1st question! Splitting oak staves from a block?
EarToday
22 Apr 2015
Manchester
Hi all,
Just joined and look forward to learning a lot here. I'm very much a newbie so it will be largely one way traffic in a woodworking sense but if I can help with anything else I'll try!
I have a long offcut of a 40mm solid oak worktop. It was left in a garage for a while and one of the ends started separating. Actually, thats good news for what I want...
I'd like to separate the staves so I can us them as legs for for a hi-fi rack.
I was just wondering if there are any tips on the best way to do this? I tried a few things last night. Starting with a heat gun and a palette knife, and managed to get about 30mm of glue out between the first piece that had started to separate naturally. and I've managed to make a start on about a metre at most (but only the top level).
But at this rate it's going to be a slow job...
I also tried some nail varnish remover (I tried to get some pure acetone from a local shop yesterday that had none) to melt the glue but that didn't seem to help much.
Is there anything else I can do or is it just a matter of putting the time in and going slowly.
Once I separate the lengths of glued staves, I can cut them to the required height (I don't mind losing a bit there), but I don't want to cut them length ways as they are already a few mm smaller than I wanted them to be so I don't want to lose any width if I can avoid it.
Hope that makes sense and I'd welcome any help or suggestions.
Thank you
ps. just added a photo
    101.5 KB
I think it would come apart eventually if you let it soak in a lake or pond for a few weeks. However you would have to dry the wood for a long time afterwards before it can be used for anything.
I think the most sensible soulution is sawing along the glue lines. Either using a rip filed hand saw or a band saw or a table saw.
Thanks, I definitely don't want to soak it as I'd like to reuse it sometime this year ;) But yes, I'm suspect that would work!
I've read things about hot vinegar, acetone, heat guns etc.
Now I've got some purchase on it, maybe a combination of the heat gun and a fine hand saw is best? I don't have a band or table saw (I really am a newbie, in terms of cutting tools I have a circular saw, a jigsaw and a router - none of which seem sensible to use on this if I want to keep the width)
You will need to cut them apart splitting will fail at the first good glued section.
I don't think you will end up with usable timber, the grain direction on work top goes all over the place making planing very difficult.
A toothing plane and scraper is the best way to clean up work top.
I would go the a wood yard and buy some square oak.
Thanks Peter. I was just hoping to be able to make use of it and save some money at the same time. The individual staves are ideal for what I want with no extra work except for making them the same height (if I could separate them!).
mouppe":3r11u78i said:
I'd use a froe.
Thanks, never heard of those until now (told you I was a newbie). I'm actually in Spain at the moment. God knows what they call them... ;)
Well, I managed to get some off. After trying lots of other things...
Near the original separation was a small piece which would have been no use anyway. So I used a jigsaw to take it out, and then prised it apart, ungluing progressively. Eventually a piece snapped off.
So (for newbies like me), this is how the worktop is put together ... ;) (see photo)
Whether I'll realistically be able to continue this process to get enough wood for my needs out of it, I don't know. I'll give it a bit more work tonight but if not I take away a lesson and go buy some new oak timber ;)
Thanks everyone for the advice.
    120.2 KB
Actually, thinking about it and looking at how much I have (a 3m length by about 5 full staves and 2 half ones at each end), I reckon I could probably cut out what I need. I only want 12 (fairly small) legs for a hifi rack. The wood is going to go to waste otherwise anyway, so I think I'll have a better look at it, see where I can cut and see if I can get what I need that way.
Just called it a night. But I've managed to cut lots of usable pieces from the board. Stopped - at least for tonight - when I got down to just two stave widths. I've been using the circular saw to rip it (and a jigsaw to cross cut) and I'm getting tired. Not a good combination (I may be a newbie but I know that one at least!)
It's meant the legs will be a few mm less wide than I hoped (maybe 37 or 38 mm square rather than 40) but I'm sure I can cope with that! And I'll need to do some squaring up - especially on the earlier cuts (probably have to use my router for that?)
But - fingers crossed - it looks like I've turned an otherwise wasted piece of wood into something useful. And I got some cut cutting practice in the process, gained a bit more confidence and learned a few other things too.
Thanks again
Just a quick update on this. I managed to rip the board with a circular saw and then made a jig to hold 170mm lengths (big enough for the max size I needed). The top and bottom of the staves were flat, obviously, but where I cut them with the saw they weren't flat or clean.
Using the jig and a router I smoothed each side, effectively 4-squaring them (with enough accuracy for my needs), and then cut them to size with a mitre saw. They are now 36mm square, clean on each side, and match up no matter which way around I put them (ie, my sides are flush with the original work top). I've possibly gone over the top in terms of accuracy considering what I'm building but I figure if I'm going to do this I should do it as best as I can (since starting I'm noticing just how crap most woodworking I see is!)
Yes, there are better and easier ways to do this but I've already spent a small fortune on tools recently and I need to get something finished to show for it (for my own sanity) and I'm getting there! I'm sure over time I'll add more tools soon (already looking for a decent table saw).
Making the jig (my first) has made me realise just what a great hobby this is. A great combination of learning how to physically handle wood and the mental side of working things out.
Thanks to everyone for the advice.
    103.4 KB
    226.7 KB
