Hegner foot switch
4 Nov 2021
PO16 9DX
I have a Hegner foot-switch currently used on a modern single speed Hegner.
I have just acquired an Axminster AT460SS (Hegner clone) which has a variable speed control.
Would anyone know whether the Hegner foot-switch would be compatible with the Axi AT460SS..........
Lorenzl
20 Feb 2022
Cambourne
In the old days the foot witch was an electrical switch. Quite often these days the foot switch is a pump to activate a pressure switch for safety.
I would say if they both use the method they would work. If electrical there should just be two wires and if pneumatic it will be a plastic tube probably pushed over a barbed fitting.
raythompson102
Ray 102
14 Apr 2022
Barnham
Hi, I also have a foot switch for my Hegner which is a variable speed. The foot switch is a genuine Hegner unit. I believe it is just an electrical switch. I also have an Axminster trade 535 scroll saw, however the later machine have an NVR switch which means if you cut the power, then you have to reset it. This tends to negate the use of having a foot switch as every time you take your foot off the switch you still have to press a start button on the scroll saw. The NVR switch is for safety reasons in case of power failure and then restored the machine would switch itself back on.
loftyhermes
15 May 2008
Market Warsop, Notts
To fit a foot switch to a machine with a NVR switch, you either have to bypass the NVR (you loose the safety feature doing this) or connect the footswitch to the output side before any other controls ie the speed control.
raythompson102
Ray 102
14 Apr 2022
Barnham
I’ve tried both with and without and I did find it useful to be able to keep both hands on the piece I was cutting. Also if occasionally a blade breaks you can stop the saw straight away.
AES
18 Feb 2011
Switzerland, near Basel
I have never understood why anyone would want a foot switch?
I agree with Ray Thompson 102 above whatnot. I'm sure they won't suit everyone, and I guess they're a bit like, say, electric windows on a car - you miss them if they're not there anymore!
Personally I use the foot switch on my EX 21 all the time, and find it does help a lot - as Ray says, keeping both hands on the job when doing tight turns for example. Especially so once you've got used to using it. But as said, I guess it's a purely personal thing, and if you haven't tried one then I guess you don't miss it.
whatknot
29 Jul 2017
Cornwall UK
I would have thought that although a scroll saw is a fairly safe machine you could easily start the machine by mistake while you fingers were not where they should be, such as just changing a blade or removing an offcut etc
I can't think of a time when a foot switch would have been useful, I can only think of the potential safety risk
Once you have switched on the saw, you have both hands free so can't see the advantage
MikeK
Moderator
Staff member
Moderator
9 Apr 2017
Germany
I was recently looking at buying a Hegner Multicut 2S with variable speed control. The foot pedal is not a switch, but a speed control, similar to a sewing machine foot control.
AES
18 Feb 2011
OK whatknot, "each to his own" as I suggested above.
NOT trying to convince you (or anyone else), but I find that especially when I need to stop cutting momentarily when doing a really sharp turn - 90 degrees or more - it's very convenient to just momentarily lift my foot off the switch while still having both hands on the work piece - and still probably rotating the work piece a little while not actually cutting.
Perhaps I should add that my foot switch is a simple "On/Off" switch, not with any speed control, like it seems the official Hegner unit has.
But as an additional very much personal comment, my EX 21 has no NVR. I know (think?) it's a UK safety regulation, but I can't see any value whatever in having one. As you suggest, even if treated with only a modicum of respect, a Scroll Saw must be just about the "safest" machine in the shop? And I can't see how even the clumsiest of user could accidentally start the machine while, say, changing a blade. Not when the "actual" On/Off switch is positioned where it is on my machine anyway.
But in one respect you are of course quite right - the potential for me to accidentally plonk my foot on to the foot switch while changing the blade is quite high I suppose. Because in my set up (no NVR remember) the "actual" On/Off switch is bypassed by the foot switch. But it hasn't happened - so far anyway!
BUT, as said "horses for courses" and all that.
Spectric
19 Feb 2015
North Cumbria
Foot switches can be very useful, it frees up both your hands and I find the one on my pillar drill very helpful and has made some jobs a lot easier. Also having a foot control for current on a TIG welder can be essential so I would have thought one on a scroll saw would make things so much easier, both hands to control the workpiece but the ability to stop without moving any hands.
Torx
11 Apr 2020
Cheshire
They’re made by Bernstein, you can buy them from RS or CPC and wire them up yourself, the Hegner one just has a kettle lead & socket on flying cables if I remember correctly.
raythompson102
Ray 102
14 Apr 2022
Barnham
Hegner do now do a foot switch that has speed control as well as on off, rather like a sewing machine foot pedal, however when asked about them I was told that it is not sold separately, but can be ordered with a new machine as an extra.
my foot switch is a Hegner unit but is just an on /off. My Hegner scroll saw also doesn’t have an NVR switch and the foot pedal plugs in between the mains sockets and the main lead to the machine. As mentioned I do find it useful to instantly stop and start the machine when I’m ready with both hands on the workpiece and when a blade breaks. (It doesn’t make me jump quite as much).
