Warksworker
Hi all,
I have an Electra Beckum HC260 which I inherited some 30+ years ago.
Having progressed from making sawdust and shavings I decided to join two boards together. Easy Peasy. Just plane the edges square, glue, clamp done.
So here’s the problem. Having planed the thin edge, I placed on a flat surface, the planer table. Only to find that the work piece rocks end to end. Tried again. Same. Other edge, same. Checked the planer table with a flat edge and seems ok.
I have checked and re-checked the blades. Followed the setup. Checked at 4 places across the bed and all seems spot on.
I’ve run the piece through the thicknesses and is perfectly flat. So no idea why I can’t get that on the planer.
Any advice, ideas etc all gratefully received.
