Hardman Sash Clamps
jasonB
26 Nov 2004
Surrey
No experience of these clamps tend to use pipe clamps myself, but if your wood is straight enough you should not need massive amounts of pressure, just enough to close the joint up. It may also help to do the glueup in stages say two groups of three strips then glue these two together, it gives you more time to align the strips before the glue starts going off.
Also remember to keep the clamp bars away from the glue line to avoid staining the oak.
Jason
beech1948
16 Aug 2004
Crowthorne, Berkshire
JasonB,
I noticed that you use pipe clamps. I'm just off to the US next week and intended buying quite a few. However, I have had a hard time finding pipe of the right size. Can you tell me what sort of pipe you use, where from etc etc.
Thanks in advance
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Beech, get the 3/4" sets. You can get the regular reach or the longer reach. Axminster have details. The 3/4" pipes are easier to get, if you can find them. Think you can get pipe sets with a connector from Axminster, if you're stuck. Quite reasonable if I remember. Don't forget the pipe will need threaded as well if you can find them at a local plumbers so might be best to buy off Axminster. If you are anywhere near a Rockler store, they do their own version of Pony clamps in blue...but have a superior design that give you more room when using the crank.
Anyway, an excuse for a picture post
Noel
stewart
16 Jan 2005
Sussex
thanks for the replies
have ordered some pipe clamps from axminster - they worked out a little more expensive but decided the versatility of different lengths was worth a little extra.
