Hi folks I wonder if someone here could shed some light on this problem I'm having?
I have made a small project from oak, of which I first danish oiled to darken the wood. I then applied a coat of fiddes semi gloss hard wax oil which went on great. I then lightly sanded the work using an 800 grit abrasive and then lightly tack clothed the work. On applying the second coat I noticed I was getting area's of gritty sort of residue building up, when this sets it is noticeable on the surface of the work. My work is clean and has no dust on the surface, is it possible my hard wax oil is going off? This is really becoming a problem for me as it means I have had to strip my work back down and start from scratch each time.
