I have two 20" crosscut hand saws - a Disston D8 and an S&J. The D8 has been well looked after and beautifully sharpened, although only a "1" is visible now to show how many TPI it had originally. That suggests that the toothing was to an odd number. Can that be right?
The S&J is 10TPI, has the reinforcing pin to the handle, albeit that it was originally somewhat uncomfortable and in that rather unpleasant bright orange varnish.
Both have taper ground blades and flex well, which I have always understood is a sign of good quality.
The sharpening on the S&J is not so good (me), but both cut very well, with that nice sharp rasp. However. in sawing to dimension on pieces of what was sold as "Croation oak", both left a splintery underside, which may now have to be cut back to avoid the rough edge.
Is there a refinement to the shape of the toothing which can be recommended to minimise this breakout?
I accept that oak is probably more prone to splintering than tighter grained timbers, but advice would be welcome.
Regards Mike
Regards Mike
