A
Anonymous
Guest
Hi all
Posty delivered a very nice box this morning contain a low angle smoother and a set of 4 Axminster scrapers + Clifton burnisher which come as a set.
I have followed Brian Bogg's advice re sharpening and preparing the scrapers as shown here (thanks Philly):
http://www.taunton.com/finewoodworking/pages/wvt088.asp
Preparation in this way is a really easy task to undertake if one has worked on plane irons and chisels before. I have avoided scrapers in the past due to a sort of fear of the unknown and their preparation but felt my time had come. 10 minutes on the stones and file and I was ready to go with 4 nice burrs on the first scraper.
I found from the very first attempt on a board that I was getting nice shavings from the scraper - much surprised as I thought it would be difficult to achieve this :shock:
I tried the scraper on Mahogany first of all which proved to be a mistake! Mahogany is prone to tearout and I found that I couldn't get a nice finish over all of the surface as in one section the grain changed direction through 180 degrees from one side of the board to the other :roll:
I was a little disappointed with the performance here as I expected the scraper to excel on problematic grains but instead i got mega tearout
I then used the low angle smoothing plane that arrived in the same box and got a nice smooth surface!
I tried scraping other pieces of Mahogany without these problems and was pretty chuffed. However, when I hand sanded (3M 240 grit) one half of a piece and scraped the other, I found very little difference between the two finishes - this surprised me as I expected a superior finish from the scraper.
I was a little dissapointed in the finish from the scraper at this point. I expected to see the beautiful 'glow' one gets from the wood after planing with a sharp iron. I love the finish that one gets on a hand planed piece of wood and have managed to avoid any working of the wood after plaing on a few smalll projects
I then turned to Oak and Ash boards along with a nice wide slab of beech. Now we are talking!! I got a lovely smooth finish from all of these and nice shavings + slightly burnt fingers (still not ordered a veritaas scrpaer holder
), I also noticed far less 'dullness' to the surface. The stock was left beautifully flat and smooth with very sharp edges between faces - a very satisfying experience :lol:
Well, there it is, my first foray into scraping. I found it easy, satisfying and enjoyable and the results I achieved in my first couple of hours should improve with practice.
Go on, give it a go if you haven't already :wink:
So, why do other members scrape when hand sanding leaves a similar finish and the scraped finish is 'inferior' to a planed finish? Cost? enjoyment of scraper use? superior results to mine after some practice?
