Great find for machinery lighting @ £6
Mooose
6 Aug 2013
United Kingdom
At my local B&Q yesterday I found this small battery-powered LED work light complete with a rotating magnetic stand. At just under £6 I thought it worth a try as a possible cheap light on my bandsaw.
All I can say is WOW - fantastic for the price.
The stand rotates 360 around the body with detents at every 45 to hold a position:
And the light is very powerful for the size:
Here it is held to my bandsaw by the magnet:
On the back it has a hook should you want to hang it somewhere:
I took the time to replace the included magnet with a powerful 15mm Neodymium though I am sure that the one it came with would be fine for most uses. It also makes use of standard AAA so easy to replace once the supplied set run out of juice.
The light also has a "torch" mode with the front-facing LED's but I don't think I will be using it for that purpose.
Link to B&Q: Diall Battery-powered LED Work light 220lm | DIY at B&Q
