Good source of sapele please
Gaz
17 Sep 2012
Hemel Hempstead
Hiya,
I've had a quote for some machined sapele £1077.00 + vat for the sizes below
57mm x 101mm:
1440mm x 8 lengths
1794mm x 4 lengths
57mm x 127mm:
1312mm x 1 length
2214mm x 2 lengths
3100mm x 2 lengths
76mm x 152mm:
305mm x 4 lengths
35mm x 13mm:
550mm x 2 lengths
1600mm x 2 lengths
2100mm x 2 lengths
3600mm x 2 lengths
4700mm x 2 lengths
45mm x 35mm:
180mm x 1 length
300mm x 1 length
45mm x 60mm
150mm x 1 length
2000mm x 1 length
45mm x 65mm
2000mm x 1 length
45mm x 85mm
330mm x 1 length
45mm x 90mm
500mm x 1 length
1600mm x 2 lengths
2100mm x 2 lengths
3600mm x 1 length
4700mm x 1 length
45mm x 160mm
600mm x 1 length
45mm x 180mm
330mm x 1 length
600mm x 1 length
45mm x 185mm
600mm x 1 length
Does this sound a bit pricey? These sizes are for a project I'm working on and the price is based on an order of ten of the above (works out to £12,924.00 inc vat) does anybody know of a place that can supply this cheaper or of an alternative hardwood that could make me a saving,
Cheers, Gaz
That lot adds up to roughly .62 of a cubic metre. if you take the cut list as finish sizes, so roughly, £600 inc VAT, obviously there will be a fair bit of waste with some of the sizes you require so i would expect to get that lot as ex timber for roughly £670.
Are they finished sizes, and do you require it finished, or just supplied ex to cut them sizes?
ordering x10 at once would make a massive difference to the price if you require it machined.
Edit just seen it is machined.
You should get it cheaper than that if ordering 10 at once. wouldnt take me more than a coupleof days to machine and would be a tidy £5k in the back pocket which is insane.
Obviously if my calculations are right.
That's what I thought olly, thanks for your help, at those prices it makes my project almost unprofitable, does anybody know of a merchant down here who is better priced?
Hi Gaz. Is that Chiltern Timber? I've always found there is some room for movement on their quotes. James Latham have a branch in Hemel albeit sheet goods, but they maybe interested in an order of that size. Think they are on Maylands.
Intriguing project! Any more details?
Hiya mickthetree,
I will give chiltern a try thank you, I'm building an orangery at the moment, the list is for a roof lantern and a couple of casement windows I need to match up, I am looking at supplying roof lanterns which Is why I'm asking for prices of ten, I have now had another price here for ten lanterns only,
Thank you for your Sapele enquiry, we can offer as follows:
Machined Sapele PSE to sizes below £3275 Lumpsum Price
57mm x 101mm: 80/1440mm 40/1794mm
57mm x 127mm: 10/1312mm 20/2214mm 20/3100mm
76mm x 152mm: 30/305mm
All sections will be supplied in lengths to cover, with minimum waste
All prices subject to Vat,
Sounds a lot better, can anyone beat that ;-) also looking for a decent supplier of aluminium glazing bars if anybody can help there, must be high quality
Cheers Gaz.
