Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
This is really a DIY question, but you never know...
... At some point in the past, in a moment of madness, I must have reached for a box of double-start screws to fix a hinge on our cloakroom door (four panel, circa 1905).
Predictably, the screws are now loose in the door frame, and I need a permanent fix that doesn't involve fitting a new frame in the opening (or letting in large pieces of wood). I last tightened them up at Easter, and now they're loose again, so that it's becoming urgent. I really don't want to re-fit the hinges somewhere else on the door either - it'll look terrible. To make things worse, the frame is butted up to a wall, so there's only the thickness of the casing proud of the wall.
Has anyone got a clever idea (glueing the screws in with some gunge or possibly dowel-pegs or something), to enable me to redo it with single-start screws properly?
It's just possible it wasn't me that did it. I'm clinging to that.
I daren't cling to the door handle - the door'll probably fall off.
E.
E.
