Glue
Cefn.
4 Dec 2020
Kidlington
Hi all. I need to fit a nut to the bottom of a pine timber bench leg. This will be used to accept a height adjustable foot. I plan to tightly chop in the nut and glue it in place to accept the foot bolt. What glue can anyone suggest please. It needs to be strong as the bench gets moved about quite a bit.
Thanks in advance.
Cefn.
baldkev
29 Apr 2020
devon
Hello again!
from your description i would recommend a threaded insert. You just need to know the thread size, like m8
Drill a hole, use an allen key to carefully wind it in. Some people put a short bolt in the insert and wind the bolt and threaded insert in together. It allows a bit more force, but i have never had to do that
Cefn.
4 Dec 2020
Kidlington
Hello again!
Hi again. That great. Never considered this. I’ll check bolt size and see where I can get a couple. Best wishes
Cefn.
Cordy
1 Dec 2014
Wigan
You can buy a box of various sizes of threaded inserts from the big river
Do trials with different drill sizes in scrap wood first
LINK
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
Do you test holes in the same wood as your piece, and the same grain orientation. I have m6 inserts that fit with 8.5mm drill in the face of pine, 9mm drill in pine end grain and oak face and 9.5mm drill in oak end grain. Put an 8.5mm hole in oak and it’ll snap the insert trying to screw it in.
Just4Fun
21 Sep 2017
Finland
Threaded inserts are a good solution and would be my prefered method but sometimes I have not had an insert handy and have used the glued nut approach. I have used Araldite or similar 2-part glue and have not had a failure.
Cefn.
4 Dec 2020
Kidlington
That’s useful. Thanks for your reply. Regards Cefn.
Cefn.
4 Dec 2020
Kidlington
Thanks for this. Very useful info. I’ll order up bits today.
Regards. Cefn.
MARK.B.
4 Jul 2012
East Yorkshire
I would think just about any epoxy glue would hold the nut in place but as others have said a threaded insert is much better,quicker and no mess or waiting for the glue to set:).
TheTiddles
14 Oct 2007
Wiltshire
Inserts are ok, but the nut is stronger if you install it in what they call a “pull-through” configuration so that the load pulls the nut into the substrate not out of it. From the sound of what you are doing the nut/insert will be pushed in under load so that’s good, but any sideways movement will have to go directly on the nut/insert which isn’t so great, in which case I’d go for a coupling nut (a long nut) in a socket so the load is distributed into the leg more
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Far better to have some sort of elevating caster arrangement for moving the bench and dropping down onto elephants foot adjusters once in the desire location.
TheTiddles
14 Oct 2007
Wiltshire
Oh, and use an epoxy of some sort, that’ll do it, doesn’t need to be anything special, rough up the nut to help it grip
Limey Lurker
16 Sep 2006
Thanks in advance.
Cefn.
I would, and have, used stud joining nuts. These are loooong nuts, and would resist sideways pressure much more than standard nuts. https://www.ebay.co.uk/itm/124262543604?_trkparms=ispr=1& I drilled a hole of a size slightly smaller than the maximum size of the nut, whacked in a good dollop of "Araldite Rapid' and forced the nut into the hole with the corners digging grooves into the sides of the hole. Then I realised that I should have filled the thread with a piece of very well greased studding so the the 'Araldite' didn't get onto the thread, which is what I did as soon as I'd made another leg.
Geriatrix
31 Jan 2020
Andover, NW Hampshire
Good idea on the stud nuts and epoxy. When you have a doh moment it would be quicker to drill to core diameter and then use a tap to clear the thread. Had to do it a few times myself. Will I ever learn?
