Glue, paint etc experiments. (Bri's learning ettemps!)
manxnorton
29 Jun 2016
Newcastle
Hi all,
Off the bat, don't string me up #-o bit i'm experimenting :mrgreen:
The 'Guru's' say, "Never use wood glue".....what does Brian do :?:
Straight in to it! :oops:
A small thing board.
Mixed:
Wood glue &white primer.
Wood glue & mahogany stain.
Wood glue with both to get lighter brown.
Ok, Part one completed.
Could it work?
We know that eventually it will dry.
Colours light..for now.
PART TWO
next morn found it like that. #-o
:lol:
The colours change diametrically (have to look up that word! and how to pronounce it!) lost the shine.
But look at the texture!!!
Where do I go from here?
Well, without abandoned it....set on Part 3 of my adventure #-o
Larger and thicker board.
Same exercise from yesterday.
'A lot going on!'...but we'll see.
Expecting negative remarks if any, but thick skinned :lol:
Comment good and bad, its how I learn, know what I mean.
The saying, "Think out of the box!" me!!...…...THINKING.. :lol:
TBC
Bri
have you got any sheet material? may help with the cupping.
also, may be necessary to apply a coat of the same to the reverse of the board to balance it out- you are effectively soaking one side in water. Alternatively, whilst experimenting, try laying it on a damp cloth whilst it dries.
Thjx Marcros,
Great advice mate =D>
Get the evening it up both sides.
I/we should see in the morn with the thicker board changes it (as I planed and thickness it perfect b4 hand) :lol:
All good skills for the help. =D>
Bri
hi bri, try cutting kerfs in the back side, it may help prevent cupping, I'd recommend plywood for next time, even hardboard is pretty good once primed, I used to paint onto white primed hardboard when I was an art student, very cost effective as well. Looks like you've had some fun :D
Bodgers":3960wq5j said:
There's a whiff of Jackson Pollock about them
Sent from my Redmi Note 5 using Tapatalk
thanks mate.
Had to look it up :lol: :lol: :lol:
but I see the crack!
Bri
the second board is 18mm pine...thought I put it on the plywood ones I cut.. #-o #-o
i'll white prime them, as ive got the primer lol.
Aye surely am having fun...taking notes etc.
Now looking at wood glue for sealing the wood b4 I epoxy resin it...trying to minimize gassing when the resins start to cure..
I like how the wood glue turns from white to well clear..lol :lol:
Bri
Carrying on from yesterday.
Heres more finding!
Defo got a bow in it...suggested plywood test next. that'll be the nexy project this afternoon :lol: :lol:
Hmmm the curing isn't finished in my heat chamber (20c) but the colour is defo changing.
If I get my epoxy resin colours today i'll mix colours and brighten it a bit...
TBC
Bri
Its missing the texture of the small board, so hoping once cured it'll turnt out like that...fingers X'd :lol:
Bri
2nd one cured
hope you see the changes of colour and the texture. :?:
now onto the 3rd one (plywood)
Primed.
1st pour
2nd pour and tilt
wonder whats the sprinkling :?: :?:
Here it is... :lol: :lol: :lol:
now into the heat chamber :D
TBC
Bri
Bri, do the bends actually matter? I personally consider the corrugations as part of your artistic endeavour. On the other hand, are you intending by this to be fitted in a frame, then..."bulwarks!"
Sam
Sam
Arhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!! took me ages typing the words out and the picture then went onto preview...and it didn't save my work.
So start again.
This is the 'Simplified' version.
Think here, I've milked the whole experiment, if you know what I mean?
Theres only so many more boards that have scibbles n stuff all over I can churn out...BASICALLY a mess on a board if I'm truthful! my Artist sister disagrees lol.
heres the 2nd & 3rd one cured.
2nd.
3rd
Both together.
Comments welcome =D>
ALB
Brian.
