Glue help please!
Phil Pascoe
29 Jan 2012
Your parts should be sanded properly before assembly, so why not put a coat or two of the chosen finish on them beforehand? That makes the glue much easier to clean off.
yetloh
1 Dec 2008
Sussex
Hi Lyn,
Apologies for the delay in replying. The glue I used was Swiss Purbond but it seems to have been taken over by Loctite and now only available in Australasia. I have had a good hunt around on the internet and the only one I could find is Bison PU Max which is said to have an open time of 1 hour and is also, like Purbond clear , unlike many which are brown or white. I have no experience of it but it sounds suitable. It is available from Glues Direct of whom I have had good personal experience. If you are unsure of its suitability I would suggest you give them a call.
Hope this helps.
Jim
Linus
24 Dec 2016
Salisbury
Hi Lyn,
Hope this helps.
Jim
No problem Jim, I'm nowhere near glue up yet. Thanks for the reply, as I said I have Gorilla PU but that expands like hell and is brown so wasn't sure how it would look. I'll give Glues Direct a shout and see what they say about the Bison.
Lyn
MARK.B.
4 Jul 2012
East Yorkshire
You Grilla glue will do the job,not had any problem with it staining the wood, leave any excess squeeze out to fully harden then clean up with a sharp chisel:)
Linus
24 Dec 2016
Salisbury
Cheers!
Lyn
TheTiddles
14 Oct 2007
Wiltshire
The OP did say he'd like some open time - D4 (or at least Everbuild D4) can be a nightmare to use in this weather. The chair will be stored indoors - 502 would give him a little longer.
D4 is a durability classification, not a drying time.
If you want to slow an adhesive down, put it in the fridge before you use it and assemble first thing in the morning when the ambient temperature is lower.
A longer open time is one option, the other is a faster assembly operation.
fhsa
1 May 2021
Essex
Lyn
I find 'The Beast' PU glue works well and is cheaper than gorilla glue. I get it from Ironmongery Direct
Best wishes, John
