heronviewer
I've been making a small (8" diameter) bowl from a dry cherry half log. It was going to be over 3½" deep but I found when I started turning it, there was some woodworm just inside the bark. I had it mounted on a faceplate, so I got it round and made a dovetail for mounting in a Patriot chuck. So far, OK. I made the dovetail 12mm deep.
When I remounted it using the dovetail and started turning, I found I had to remove far more of the top of the bowl to get rid of the worm holes than I had expected. The 12mm dovetail looks a bit of a luxury as I have lost quite a lot of the depth I might have had. It will be about 2" deep now !
I should have used a glue chuck in retrospect, but the only time I have used one (with hot melt glue), the joint failed very quickly when I was turning.
What experiences have others had with glue chucks on reasonable sized pieces ?
