Glue and Teak Results
DavidN
28 Sep 2004
Woking Surrey
Gentlemen thank you for all your advise
I glued 21max260mmx860mm pieces successfully
using two methods
1st....sanded both edges with 120 grit sandpaper use meths to clean both surfaces the using biscuits and Tilbond II glue it worked very well
2nd method I did not use the meths as using the sandpaper then blowing clean the surfaces where clear of oil This method worked as well
As I glued both items along the 860mm x 21mm edge this gave a very good glue area
Many thanks
David Nevin
Adam
10 Sep 2003
UK
Great - whatcha making though? Any piccies for us to see?
Adam
DavidN
28 Sep 2004
Woking Surrey
As soon as I have finished the TV cabinet I will post the pictures
I have to fit it in with my golf ???
David Nevin
