hi all
looking to fix together a garden bench made from drift wood.
here it is, can anyone advise on the best way to fix the top plank to the legs -thinking one of the following:
1) coach screws countersunk into the top plank downwards into the legs
something like these m8 x 120mm coach screws:
http://www.screwfix.com/p/turbo-coach-s ... f-50/52740
2) smaller wooden block under the bench - block screwed into top plant, block screwed into legs - I could get away with much smaller coach screws but can't help feeling it would not look quite so good?
3) wooden dowels - x2 dowels each side from legs into top plant, glued with exterior pva glue.
4) or perhaps a a bit of dowel and then 2 coach screws?
Then moving on to the bottom cross piece - coach screw through and glued?
Finish wise, I was think of a few coats of Danish Oil? it has been roughly belt sanded and I want to keep it rustic looking, would the Danish Oil be a good choice?
any advice much appreciated!
cheers
Grafter
cheers
Grafter
