FTAGH, Inca Bandsaw, Spares Or Repair
custard
20 Aug 2008
Hampshire
Free to a good home.
Inca bandsaw that was damaged in transit. The table is bent, the table supporting trunnion is broken, one of the cast legs is bent and cracked. The mystery is the motor, it was working fine but now hums but won't spin!
This is collect only, South Coast in Hampshire (New Forest), mid way between Southampton and Bournemouth.
PM if you want it.
They’ll have to fix it first Tom!
seriously, I don’t want anyone to make a long journey to collect this and under estimate the scale of repair required.
For example the broken table trunnion is part of the main body aluminium casting, this isn’t a simple fix!
Bummer, but good on you for trying to find a good use for it.
That doesn't like like an original table.
Nevertheless, hopefully someone can put this back together again. I guess it will require someone who can weld aluminium?
A bit of steel plate would do the job fine, and nice to have a prototype to copy aswell.
Worth having an excuse to go out and buy a forty quid second hand ark welder :)
