Freud T&G router set
Steve
6 Nov 2002
Welling, Kent
I'm making a seven cupboard doors from some fantastic hard maple, and needed to spring for a T&G set. I've never used Freud cutters, so I thought I'd give them a spin.
They looked substantial and well-made, and I must admint the price point suggested top quality. Cheap they weren't.
Revved up the router to about 1200, slowly fed the heavenly maple through on a fairly light cut. The tongues are more locational than structural, so there was no need to go deep.
It seemed to cut well, and then I noticed that about a third of one of the cutter blades had flown off from the bottom.
Somewhat less than amused, I carried on with my 1 & 2/3rds cutter, slowly, carefully and a little bit hesitatingly. I didn't fancy copping a piece of THAT in the face. It would be like being shot with a .22
The remaining cutter and a bit stayed and I still got a tongue, although one edge needed cleaning up.
Then to the groove. The groove cutter is four blades at slightly alternating heights. Cut the first one, checked the cutter and found that TWO had come off clean - not broken, just divorced from the brazing altogether.
I doubt there's any need to add further comment, except to say that I overlooked the bargepole.
Chris Knight
14 Jan 2004
SE London - NW Kent
Steve,
Very worrying indeed, as you say it would be like being shot if a bit of carbide hit you. I am glad it didn't - and you are probably just as pleased that your maple came though unscathed?
As you say, the Freud cutters look the business and are not cheap (I just bought a couple of Freud roundover bits for my chair - I shall make sure I put a face mask on when I use them!)
Bargepole advice noted.
Aragorn
6 Feb 2004
East Sussex
My god! That is really bad. You were brave to carry on using the set at all!
Presumably Freud don't specify as highly as Trend.
What are you going to do now? I imagine Freud will be hearing about this?
A
Steve
6 Nov 2002
Welling, Kent
The thought of taking one of those bits to that beautiful chair fills me with dread and foreboding... :cry:
I'm sticking with Trend or good ol' Wealden from now on!
(Haven't tried any CMT cutters yet - they really do seem expensive).
Steve
A
Anonymous
Guest
Shocking and dangerous to boot! :shock: :shock:
Thankfully you weren't hurt
Send 'em back for full refund and buy Trend which are (I think) cheaper. Even the free cutters that came with my cheapo PRC router didn't break!
Tony
Steve
6 Nov 2002
Welling, Kent
I bought them at the Ally Pally show - I think from the Craft Supplies stand. No receipt or proof of purchase - not that they didn't give me a receipt, just that I have no idea what happened to it!
I'll contact Freud and let you know how I get on. Should be interesting.
Steve
Alf
22 Oct 2003
Up the proverbial creek
Yikes, Steve. :shock: Lucky escape. I've had a DT cutter bust on me once, and that was worrying enough despite being much smaller in diameter.
As to Freud, I have a set of theirs and have had no trouble. Certainly they have (had?) a reputation for good stuff. I did hear rumour that they will make to a budget in some instances though - the "Diablo" range from Screwfix is such a case I believe. Freud have given a good response before IIRC, so finger's crossed.
Cheers, Alf
Adam
10 Sep 2003
UK
I've heard the "budget" rumour for screwfix stuff too - from my local shop.
Apparently Screwfix offer a "fixed" price, and Freud have it manufactured to that price.
A
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Steve
Sorry to hear about your troubles, glad that you're still in one piece. Did you buy their diablo range from Screwfix?
I've got a set of Freud 1/2" cutters and cannot fault them. Personally I believe that they are a higher spec than Trend.
Now, however, I buy mine from Wealden. They are excellent, cheaper than Trend/Freud and their customer service is brilliant.
Well worth a try.
Neil
kafkaian
14 Feb 2005
Birmingham, UK
Newbie_Neil":37k64l1s said:
Hi Steve
Well worth a try.
Neil
Do we have a link for Wealden? Shocked by this. My cheap set from B&Q haven't done this!!
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
I second that. I have three sets of their 6mm t&g cutters (one set to use while the other two are being sharpened)
jasonB
26 Nov 2004
Surrey
I use a lot of Wealdens cutters and have always found them very good like wise CMT though I have only got a few of these.
I also get my spindle cutters from Wealden, they do the KWO ones.
Jason
Chris Knight
14 Jan 2004
SE London - NW Kent
I have a couple of KWO replaceable insert router bits and I think they are fantastic. They cut cleaner mortises than my expensive solid carbide spiral cutters. I also rate Wealden and will always buy from them for preference if they have what I want.
jasonB
26 Nov 2004
Surrey
I use the same replacables, very cost effective for doing worktop joints.
Jason
Midnight
11 Oct 2003
Scotland
Steve, I gotta admit this shocked me.. I've used Freud as my "go to" cutters for over 4 years now without fault; personally I've nothing but praise for em..
Please, contact them directly and advise re your experience. Irrespective of which range the cutters came from, carbide schrappnel shouldn't happen... period... they need to know they have a QA issue here...
