Fretsaw Scrollsaw ?
Hi Dave. A fretsaw is a hand tool that is mainly used by carpenters to scribe a skirting board into another one that is at right angles. Years ago in a bygone era all intricate work was done by hand using a fret saw and it was a skill that only came with years of experience. Today we have scroll saws which to a certain extent has replaced the fret saw for many applications and just to confuse the issue a bit more you can do fret wrok using a scoll saw but fret work usually refers to intricate cut out type work like portraits etc. Hope this helps.
That's a coping saw - and the process is called (naturally enough) coping.
BugBear
Nowadays the terms are interchangeable. However, there is a difference between scrolled work and fretted work in that a scroll adorns the exterior of an item whereas fretwork pierces the interior of an item. Take a look at the following piece of bric-a-brac:
The external shaping of the frame has been scrolled whereas the heart that has been cut from the centre is fretwork.
Technically, a scroll saw should not have a blade that can be detached to facilitate fretwork, but that would be ridiculous; every saw used for this type of work has detachable blades. It is hard to say where the confusion first arose between fretting and scrolling, but confusion has certainly arisen. It seems to me that the term 'scroll saw' is one which has been adopted readily in America whereas Europeans are more likely to use the more linguistically accurate name of 'fret saw'.
I don't think so; it's a "all herrings are fish" kind of deal. All "scroll saws" can be called "fret saws", since to the best of my knowledge "scroll saw" is an American term for a (typically) electrically powered, 18" throat machine used to make complex cuts in thin wood.
In the UK this can be called a "fret saw".
However, in the UK, "fret saw" can also mean this:
I'm not sure USA-ians even acknowledge the existence of those :)
BugBear
Oh, come on - this isn't the Hand Tools section :) . Nobody who scrolls (frets? :) ) would say that the terms are not interchangeable nowadays. Yes, it's true that a fret saw can be either mechanical or manual whereas a scroll saw always seems to be mechanical, but that really is splitting hairs.
I'm a born hair splitter. :D :D :D
Don't get me started on "jewellers saw" and "piercing saw".
BugBear
Hi,
What did Shakespeare say:- "A rose by any other name smells just as sweet" - (or similar)
A good initial query though.
Bob H.
In general, a Fretsaw is the British description of an age old saw used in Britain.
The Yanks have to be different so they call it a Scroll Saw and unfortunately, we follow like sheep.
End of !
